This class represents general image types to be drawn on the map, such as .BMP, .JPG, .PNG, etc.
GdiPlusRasterLayer(String,String)
GdiPlusRasterLayer(String,RectangleShape)
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In GdiPlusRasterLayer, we override this API and mark it as true.
This property gets and sets the path and filename of the image file you want to use.
This should be a complete path and filename for the image file.
Gets or sets the interpolation mode associated with this System.Drawing.Graphics.
If you wish, you can pass in your own stream to represent the image. The stream can come from a variety of places, including isolated storage, a compressed file, or an encrypted stream. When the image is finished with the stream it will dispose of it, so be sure to keep this in mind when passing the stream in. If you do not pass in an alternate stream, the class will attempt to load the file from the file system using the PathFileName property.
