thinkgeo.mapsuite.core.requesteddatawfsfeaturesourceeventargs
ThinkGeo.MapSuite.Core.RequestedDataWfsFeatureSourceEventArgs
This class represents the parameters passed in through the RequestedData event in WfsFeatureSource.
      • ThinkGeo.MapSuite.Core.RequestedDataWfsFeatureSourceEventArgs
RequestedDataWfsFeatureSourceEventArgs()
  • This is a default constructor for the class.
  • None
RequestedDataWfsFeatureSourceEventArgs(String,String)
  • None
  • serviceUrl
    • Description:This parameter specified the serviceUrl for the WfsFeatureSource.
  • xmlResponse
    • Description:This parameter specified the xmlResponse string get back from the service Url.
XmlResponse
This property gets or sets the xml response string back from for the WfsFeatureSource service url.
ServiceUrl
This property gets or sets the serviceUrl for the WfsFeatureSource.
thinkgeo.mapsuite.core.requesteddatawfsfeaturesourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
