thinkgeo.mapsuite.core.mapshape
ThinkGeo.MapSuite.Core.MapShape
This class represent a unit can be drawn on map. Each MapShape composes of a feature and a ZoomLevelSet to control its drawing zoomlevels.
    • ThinkGeo.MapSuite.Core.MapShape
MapShape()
  • This is the default constructor for the MapShape.
  • None
MapShape(Feature)
  • None
  • feature
    • Type:Feature
    • Description:This parameter is the feature for this MapShape.
Feature
This property returns the feature representing the MapShape.
ZoomLevels
This property returns the ZoomLevel to control the drawing of the MapShape.
thinkgeo.mapsuite.core.mapshape.txt · Last modified: 2017/03/16 21:59 (external edit)
