thinkgeo.mapsuite.core.regexmatching
ThinkGeo.MapSuite.Core.RegexMatching
This enumeration defines the matching criteria for regular expression matching.
This is used to determine how much of a string needs to match a regular expression in order to declare it a match for that expression. Sometimes, you only need one part of the string to match in order for the expression to be considered a match; other times you may want the entire string to match.
Items
MatchFirstOnly
  • Summary:Only part of the string must match the regular expression.
MatchAll
  • Summary:The entire string must match the regular expression.
thinkgeo.mapsuite.core.regexmatching.txt · Last modified: 2017/03/16 21:59 (external edit)
