thinkgeo.mapsuite.core.geoobjectmodeler
ThinkGeo.MapSuite.Core.GeoObjectModeler
This class creates models for objects and recreates objects from models.
    • ThinkGeo.MapSuite.Core.GeoObjectModeler
GeoObjectModeler()
  • Creates an instance of GeoObjectModeler.
CreateModel(Object,GeoObjectModelerMemberTypes,BindingFlags,GeoObjectModelerDefaultValueMode)
  • Creates model for an object.
  • Description:The model that represent the object.
  • objectToModel
    • Description:The object to model.
  • bindingFlags
    • Type:BindingFlags
    • Description:The binding flags.
CreateObject(GeoObjectModel)
  • Creates an object from a model.
  • Description:The object recreated from the model.
GetMembers(Type,GeoObjectModelerMemberTypes)
  • Gets members of a type.
  • Type:Collection<MemberInfo>
  • Description:The members of a type.
  • type
    • Description:The type.
GetMembersCore(Type,GeoObjectModelerMemberTypes)
  • type
OnCreatingMemberNode(CreatingMemberNodeGeoObjectModelerEventArgs)
OnCreatingMemberObject(CreatingMemberObjectGeoObjectModelerEventArgs)
OnCreatedMemberNode(CreatedMemberNodeGeoObjectModelerEventArgs)
OnCreatedMemberObject(CreatedMemberObjectGeoObjectModelerEventArgs)
CreateMemberNode(String,Object,Type,Object,GeoObjectNode)
  • Creates a node for a member.
  • memberName
    • Description:The member name.
  • memberValue
    • Description:The member value.
  • memberType
    • Description:The member type.
  • memberOwner
    • Description:The member's owner(parent) object.
  • baseMemberNode
CreateMemberNodeCore(String,Object,Type,Object,GeoObjectNode)
  • memberName
  • memberValue
  • memberType
  • memberOwner
  • baseMemberNode
CreateMemberObject(String,Type,Object,GeoObjectNode)
  • Creates an object from a node.
  • memberName
  • memberType
  • memberOwner
CreateMemberObjectCore(String,Type,Object,GeoObjectNode)
  • memberName
  • memberType
  • memberOwner
IsGeneratingCode
CreatingMemberNode This event happens when the modeler is creating a node for a member(field or property).
Event Arguments:CreatingMemberNodeGeoObjectModelerEventArgs
CreatedMemberNode This event happens when the modeler has created a node for a member(field or property).
Event Arguments:CreatedMemberNodeGeoObjectModelerEventArgs
CreatingMemberObject This event happens when the modeler is recreating an object from a node.
Event Arguments:CreatingMemberObjectGeoObjectModelerEventArgs
CreatedMemberObject This event happens when the modeler has created an object from a node.
thinkgeo.mapsuite.core.geoobjectmodeler.txt · Last modified: 2017/03/16 21:59 (external edit)
