thinkgeo.mapsuite.portablecore.tabdbfcolumn
ThinkGeo.MapSuite.Core.TabDbfColumn
    • ThinkGeo.MapSuite.Core.FeatureSourceColumn
      • ThinkGeo.MapSuite.Core.DbfColumn
        • ThinkGeo.MapSuite.Core.TabDbfColumn
TabDbfColumn()
  • This method is the constructor for the DbfColumn.
  • None
TabDbfColumn(String,DbfColumnType,Int32,Int32,Boolean,Boolean)
  • None
  • columnName
    • Description:This parameter represents the name of the column in the DBF.
  • columnType
    • Description:This parameter represents the type of the column in the DBF.
  • length
    • Description:This parameter represents the length of the column in the DBF.
  • decimalLength
    • Description:This parameter represents the number of decimal places the column has, if it is a numeric type.
  • buildIndex
  • uniqueIndexColumnValues
BuildIndex
  • This property returns the index of the column in the DBF.
UniqueIndexColumnValues
  • This property returns the value of the column in the DBF is unique or not.
ColumnType
Length
DecimalLength
ColumnName
TypeName
MaxLength
thinkgeo.mapsuite.portablecore.tabdbfcolumn.txt · Last modified: 2017/03/16 21:59 (external edit)
