thinkgeo.mapsuite.core.createdmembernodegeoobjectmodelereventargs
ThinkGeo.MapSuite.Core.CreatedMemberNodeGeoObjectModelerEventArgs
This class represents the parameters passed in through the CreatedMemberNode event.
      • ThinkGeo.MapSuite.Core.CreatedMemberNodeGeoObjectModelerEventArgs
CreatedMemberNodeGeoObjectModelerEventArgs()
  • Creates an instance of MemberNodeCreatedGeoObjectModelerEventArgs.
CreatedMemberNodeGeoObjectModelerEventArgs(String,Object,Type,Object,GeoObjectNode)
  • Creates an instance of MemberNodeCreatedGeoObjectModelerEventArgs with name, value, type, owner and node.
  • name
    • Description:The name of the member.
  • value
    • Description:The value of the member.
  • type
    • Description:The type of the member.
  • owner
    • Description:The owner of the member.
Gets or sets the name of the member.
Value
Gets or sets the value of the member.
Type
Gets or sets the type of the member.
Owner
Gets or sets the owner of the member.
Node
Gets or sets the node of the member.
thinkgeo.mapsuite.core.createdmembernodegeoobjectmodelereventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
