thinkgeo.mapsuite.portable.portabletimer
ThinkGeo.MapSuite.Portable.PortableTimer
    • ThinkGeo.MapSuite.Portable.PortableTimer
PortableTimer()
Create()
CreateCore()
Create(Double)
  • interval
CreateCore(Double)
  • interval
Start(Object)
  • concrete
StartCore(Object)
  • concrete
Stop(Object)
  • concrete
StopCore(Object)
  • concrete
SetInternal(Object,Double)
  • concrete
  • interval
SetIntervalCore(Object,Double)
  • concrete
  • interval
GetInternal(Object)
  • concrete
GetInternalCore(Object)
  • concrete
SetElapsed(Object,Action)
  • concrete
  • value
    • Type:Action
SetElapsedCore(Object,Action)
  • concrete
  • value
    • Type:Action
thinkgeo.mapsuite.portable.portabletimer.txt · Last modified: 2017/03/16 21:59 (external edit)
