thinkgeo.mapsuite.core.dbflinksource
ThinkGeo.MapSuite.Core.DbfLinkSource
    • ThinkGeo.MapSuite.Core.LinkSource
      • ThinkGeo.MapSuite.Core.DbfLinkSource
DbfLinkSource()
DbfLinkSource(String)
  • pathFilename
DbfLinkSource(String,String)
  • pathFilename
  • name
DbfLinkSource(String,String,Boolean)
  • pathFilename
  • name
  • isCacheEnabled
Open()
Close()
GetColumns()
OpenCore()
CloseCore()
GetColumnsCore()
PathFilename
Records
Id
IsOpen
LinkExpressions
  • Type:Collection<String>
LinkSources
ColumnNamesToExclude
IsCacheEnabled
NameInLowerCase
thinkgeo.mapsuite.core.dbflinksource.txt · Last modified: 2017/03/16 21:59 (external edit)
