thinkgeo.mapsuite.core.adornmentlayersdrawingeventargs
ThinkGeo.MapSuite.Core.AdornmentLayersDrawingEventArgs
      • ThinkGeo.MapSuite.Core.AdornmentLayersDrawingEventArgs
AdornmentLayersDrawingEventArgs()
  • This is the default constructor for the class.
AdornmentLayersDrawingEventArgs(IEnumerable<AdornmentLayer>)
  • None
  • adornmentLayers
    • Type:IEnumerable<AdornmentLayer>
    • Description:This parameter is the AdornmentLayers that will be drawn.
AdornmentLayers
This property gets and sets the AdornmentLayers that will be drawn.
thinkgeo.mapsuite.core.adornmentlayersdrawingeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
