thinkgeo.mapsuite.core.drawingpenalignment
ThinkGeo.MapSuite.Core.DrawingPenAlignment
Items
Center
  • Summary:Specifies that the GeoPen object is centered over the theoretical line.
Inset
  • Summary:Specifies that the GeoPen is positioned on the inside of the theoretical line.
Left
  • Summary:Specifies the GeoPen is positioned to the left of the theoretical line.
Outset
  • Summary:Specifies the GeoPen is positioned on the outside of the theoretical line.
Right
  • Summary:Specifies the GeoPen is positioned to the right of the theoretical line.
thinkgeo.mapsuite.core.drawingpenalignment.txt · Last modified: 2017/03/16 21:59 (external edit)
