thinkgeo.mapsuite.core.encryptedfilebitmaptilecache
ThinkGeo.MapSuite.Core.EncryptedFileBitmapTileCache
    • ThinkGeo.MapSuite.Core.TileCache
      • ThinkGeo.MapSuite.Core.BitmapTileCache
        • ThinkGeo.MapSuite.Core.FileBitmapTileCache
          • ThinkGeo.MapSuite.Core.EncryptedFileBitmapTileCache
EncryptedFileBitmapTileCache()
  • This is the default constructor.
  • If you use this constructor, you have to set the properties manually.
EncryptedFileBitmapTileCache(String)
  • This is the overloads constructor.
  • If you use this constructor, the other properties are set with default values.
  • cacheDirectory
    • Description:This parameter specifies the cache directory of the tile cache.
EncryptedFileBitmapTileCache(String,String)
  • cacheDirectory
  • cacheId
    • Description:This parameter specifies the cache id of the tile cache.
EncryptedFileBitmapTileCache(String,String,TileImageFormat,TileMatrix)
  • This is the constructor with all the parameters needed passed in.
  • cacheDirectory
  • cacheId
  • imageFormat
    • Description:This parameter specifies the image format of the tile cahce.
  • tileMatrix
    • Description:This parameter specifies the tile matrix of the tile cache.
ClearCache(TimeSpan)
  • tileExpiration
    • Type:TimeSpan
ClearCache(Double)
  • maxSizeInMegabytes
ClearCache(TimeSpan,Double)
  • tileExpiration
    • Type:TimeSpan
GetTileImageFileNames(RectangleShape)
  • Type:Collection<String>
GetTileImageFileName(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
GetHigherScaleTile(RectangleShape,Double)
  • tileScale
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(Bitmap,RectangleShape,Boolean)
  • bitmap
    • Type:Bitmap
  • saveContainedCellsOnly
SaveTiles(Bitmap,RectangleShape)
  • bitmap
    • Type:Bitmap
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
SaveTileCore(Tile)
  • tile
    • Type:Tile
GetTileCore(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
DeleteTileCore(Tile)
  • tile
    • Type:Tile
CheckExpiration(String)
  • tileImageFileName
GetBinariesFromBitmap(Bitmap)
  • Type:Byte[]
  • bitmap
    • Type:Bitmap
ClearCacheCore()
GetHigherScaleTileCore(RectangleShape,Double)
  • tileScale
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
CacheDirectory
ExpirationTime
  • Type:TimeSpan
TileMatrix
TileAccessMode
NoDataTileImage
  • Type:Bitmap
LoadingTileImage
  • Type:Bitmap
ImageFormat
JpegQuality
  • Type:Int16
CacheId
GottenCacheImage N/A
Event Arguments:GottenCacheImageBitmapTileCacheEventArgs
GettingCacheImage N/A
thinkgeo.mapsuite.core.encryptedfilebitmaptilecache.txt · Last modified: 2017/03/16 21:59 (external edit)
