thinkgeo.mapsuite.core.googlemapslayer
ThinkGeo.MapSuite.Core.GoogleMapsLayer
Represents an object that encapsulates a Google Map layer.
      • ThinkGeo.MapSuite.Core.GoogleMapsLayer
GoogleMapsLayer()
  • This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually.
  • None
GoogleMapsLayer(String,String,String)
  • This constructor initializes a new layer and assgin a license key.
  • cacheDirectory
    • Description:The cache directory for the GoogleMapLayer.
  • clientId
    • Description:The clientId for the GoogleMapLayer.
  • privateKey
    • Description:The privateKey for the GoogleMapLayer.
GoogleMapsLayer(String,String,String,WebProxy)
  • This constructor initializes a new layer and assgin a license key and initilize a cache directory.
  • cacheDirectory
    • Description:cache directory which stored the cache image.
  • clientId
  • privateKey
  • webProxy
    • Type:WebProxy
GetGoogleMapsImage(Double,Double,Int32,Double,Double)
  • Type:Bitmap
  • longitude
  • latitude
  • zoomLevelNumber
  • tileWidth
  • tileHeight
GetPictureFormat()
  • Get picture format string which will use for request url.
  • Description:Get picture format string which will use for request url.
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
SendWebRequest(WebRequest)
  • Type:WebResponse
  • webRequest
    • Type:WebRequest
SendWebRequestCore(WebRequest)
  • Type:WebResponse
  • webRequest
    • Type:WebRequest
GetGoogleMapsImageCore(Double,Double,Int32,Double,Double)
  • Type:Bitmap
  • longitude
  • latitude
  • zoomLevelNumber
  • tileWidth
  • tileHeight
OnCreatingRequest(CreatingRequestGoogleMapsLayerEventArgs)
OnSendingWebRequest(SendingWebRequestEventArgs)
OnSentWebRequest(SentWebRequestEventArgs)
OpenCore()
  • This method opens the Layer so that it is initialized and ready to use.
  • This abstract method is called from the concrete public method Open. The open method plays an important role, as it is responsible for initializing the Layer. Most methods on the Layer will throw an exception if the state of the Layer is not opened. When the map draws each layer, the layer will be opened as one of its first steps; then, after it is finished drawing with that layer, it will close it. In this way, we are sure to release all resources used by the Layer. When implementing the abstract method, consider opening the FeatureSource or RasterSource. You will get a chance to close these in the Close method of the Layer.
  • Description:None
CloseCore()
  • This method closes the Layer and releases any resources it was using.
  • This abstract method is called from the concrete public method Close. The close method plays an important role in the life cycle of the Layer. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed Layer is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
  • Description:None
  • This method draws the Layer.
  • This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the layer based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:None
  • canvas
    • Type:GeoCanvas
    • Description:This parameter is the canvas object or a GeoImage to draw on.
  • labelsInAllLayers
    • Description:This parameter represents the labels used for collision detection and duplication checking.
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
GetBoundingBoxCore()
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
TileMode
TileWidth
TileHeight
PictureFormat
Gets or sets a value represents the image format of the image.
MapType
Gets or sets a value represents the map type of the GoogleMaps.
TimeoutInSeconds
Gets or sets a value represents the request timeout from the GoogleMaps server.
ClientId
Gets or sets a value to access the special features of Google Maps API Premier, you must provide a client ID when accessing any of the Premier API libraries or services. When registering for Google Maps API Premier, you will receive this client ID from Google Enterprise Support. All client IDs begin with a gme- prefix.
PrivateKey
Gets or sets a value that is unique to your client ID, please keep your key secure.
TileCache
ProjectionFromSphericalMercator
ProjectedTileCache
TileExpiration
  • Type:TimeSpan
MaxCacheSizeInMegabytes
NoDataTileImage
Gets or sets a value represents the image with 512*512 when no data can access.
If you set the image's size is different from 512*512, it will be compressed or stretched to 512*512.
  • Type:Bitmap
WebProxy
This property gets or sets the proxy used for requesting a Web Response.
  • Type:WebProxy
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
HasBoundingBox
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
BufferImages
  • Type:Dictionary<Int32,Bitmap>
IsOpenCore
CreatingRequest This event is called before creating the reqeust for google maps.
This event is called before creating the reqeust for google maps. It is typical that user want to get the url of reqeust and modify it according to their requirements.
Event Arguments:CreatingRequestGoogleMapsLayerEventArgs
SendingWebRequest N/A
Event Arguments:SendingWebRequestEventArgs
SentWebRequest N/A
Event Arguments:SentWebRequestEventArgs
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.core.googlemapslayer.txt · Last modified: 2017/03/16 21:59 (external edit)
