thinkgeo.mapsuite.routing.routingcommittingtransactioneventargs
ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs
      • ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs
RoutingCommittingTransactionEventArgs(RoutingTransactionBuffer)
  • This is the default constructor for the event.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs#RoutingCommittingTransactionEventArgs.28RoutingTransactionBuffer.29
  • transactionBuffer
    • Description:This parameter represents the transaction buffer that needs to be committed.
RoutingCommittingTransactionEventArgs()
  • This is the constructor of the event arguments.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs#RoutingCommittingTransactionEventArgs.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittingTransactionEventArgs#MemberwiseClone.28.29
Cancel
This property allows you to cancel the transaction.
TransactionBuffer
This property returns the transaction buffer that needs to be committed.
thinkgeo.mapsuite.routing.routingcommittingtransactioneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
