thinkgeo.mapsuite.core.jeffersonianhelper
ThinkGeo.MapSuite.Core.JeffersonianHelper
    • ThinkGeo.MapSuite.Core.JeffersonianHelper
Split(Feature,Int32,GeographyUnit,Int32,JeffersonianSplitMode,Boolean)
  • section
    • Type:Feature
    • Description:The polygon to split.
  • sectionNumber
    • Description:The number which the polygon belongs to.
  • cornerPointTolerancePercentage
    • Description:Percentage value of the tolerance, e.g. 50 means 50%
  • isSection
SplitNorthSouth(Feature,GeographyUnit,Int32)
  • Type:Collection<Feature>
  • aliquotPart
SplitWestEast(Feature,GeographyUnit,Int32)
  • aliquotPart
SplitIntoQuaters(Feature,GeographyUnit,Int32)
  • aliquotPart
FindAliquotPart(Feature,String,GeographyUnit,Int32,JeffersonianSplitMode)
  • section
  • jeffersonianString
FindAliquotPart(Feature,String,GeographyUnit,Int32,JeffersonianSplitMode,Boolean)
  • section
  • isSection
FindAliquotPartForPartSection(Feature,String,GeographyUnit,Int32,JeffersonianSplitMode)
  • section
FindAliquotPart(Feature,Int32,String,GeographyUnit,Int32,JeffersonianSplitMode)
  • section
  • sectionNumber
GetSectionNumber(Feature,GeographyUnit)
  • section
CanSplit(Feature,GeographyUnit)
  • aliquotPart
CanFindAliquotPart(Feature,GeographyUnit)
  • aliquotPart
thinkgeo.mapsuite.core.jeffersonianhelper.txt · Last modified: 2017/03/16 21:59 (external edit)
