thinkgeo.mapsuite.core.spatialdatatype
ThinkGeo.MapSuite.Core.SpatialDataType
This property gets the spatial data type in the MsSql2008FeatureSource.
In SQL Server 2008 there are two new data types for storing spatial information: GeometryType and GeographyType.The Geometry data type supports a flat 2D surface with XY coordinates for points. Points can be lines , on line string and mark edges of polygons.The Geography data type uses the same methods but the data type reflects the fact that we live on a curved 2D surface popularly known as the earth.
Items
Unknown
  • Summary:N/A
Geometry
  • Summary:The GeometryType supported in SQL Server2008.
Geography
  • Summary:The GeographyType supported in SQL Server2008.
thinkgeo.mapsuite.core.spatialdatatype.txt · Last modified: 2017/03/16 21:59 (external edit)
