SetPosition(Double,Double,PointShape,PrintingUnit)
SetPosition(Double,Double,Double,Double,PrintingUnit)
SetPosition(Double,Double,LayerAnchorLocation,PointShape,PrintingUnit)
SetPosition(Double,Double,LayerAnchorLocation,Double,Double,PrintingUnit)
SetPositionCore(Double,Double,Double,Double,PrintingUnit)
This propery is a dictionary that exposes what text will be drawn to represent the ScaleLine Unit.
We will display different letters for different units of measure; for example: “m” for meters, “ft” for feet, etc.
Gets or sets the UnitSystem (Imperial/Metric) to be used for the ScaleBar.
By setting this property, you can control whether to use a metric or imperial measurement system for the ScaleBar.
Gets or sets the thickness of the ScaleBar. It is an integer value representing the height of the ScaleBar in screen units.
You can use this property to set the maximum width that you want the ScaleBar to occupy on the map. The ScaleBarAdornmentLayer will automatically adjust its size based upon the current extent of the map. By setting this property, you can control the maximum width the ScaleBar will occupy on the map.
This BarBrush property will give you full control over the appearance of the ScaleBarAdornmentLayer.
The property is the GeoBrush that will be used to draw the alternate ScaleBar.
This AlternateBarBrush property will give you full control over the appearance of the ScaleBarAdornmentLayer.
Gets or sets the color for the ScaleBarAdornmentLayer's mask, if the HasMask property is set to true.
Gets or sets whether the ScaleBar will have a mask or not. A boolean value representing whether or not a mask is shown.
Depending upon the look of your map and your requirements, you may or may not want a mask on the ScaleBar. You can control whether or not the ScaleBar has a mask by setting this property. If you set the HasMask property to true, be sure to specify a mask color (or texture) by using the MaskBrush property.
By using this property you can control the border of the mask, if the HasMask property is set to true. If you do not want a contour or border to show, you should set the pen to transparent.
