GetAccuratePerimeter(String,DistanceUnit,DistanceCalculationMode)
GetAccurateArea(Int32,AreaUnit,DistanceCalculationMode)
GetAccurateArea(String,AreaUnit,DistanceCalculationMode)
RemoveVertex(Vertex,MultipolygonShape)
GetAccuratePerimeterCore(String,DistanceUnit,DistanceCalculationMode)
GetAccurateAreaCore(String,AreaUnit,DistanceCalculationMode)
