thinkgeo.mapsuite.core.multilineshape
ThinkGeo.MapSuite.Core.MultilineShape
    • ThinkGeo.MapSuite.Core.BaseShape
      • ThinkGeo.MapSuite.Core.LineBaseShape
        • ThinkGeo.MapSuite.Core.MultilineShape
MultilineShape()
  • This constructor creates the MultilineShape.
  • None
MultilineShape(IEnumerable<LineShape>)
  • lineShapes
    • Type:IEnumerable<LineShape>
MultilineShape(String)
  • None
  • wellKnownText
MultilineShape(Byte[])
  • None
  • wellKnownBinary
    • Type:Byte[]
Reorder(PointShape,Double)
  • This API is used to make the lines within the Multiline ordered.
  • An ordered Multiline means that we can walk though the MultiLine from the first point to the last point without any branches, and that each line's end points should be within the given tolerance. If using this overload, the unit of the Multiline and the tolerance are both defaulted to meters. Please use the other overload if you want to specify the units yourself.
  • Description:Returns a re-ordered MultilineShape.
  • startPoint
    • Description:This parameter specifies the start point of the resulting re-ordered MultilineShape.
  • tolerance
    • Description:This parameter specifies the tolerance between each line among the lines in the Multiline. This parameter is very critial. If it is too large or too samll, the re-order cannot suceed.
Reorder(PointShape,Double,GeographyUnit,DistanceUnit)
  • An ordered Multiline means that we can walk though the MultiLine from the first point to the last point without any branches, and that each line's end points should be within the given tolerance. When using this overload, you can specify the unit for the Multiline as well as the unit for the tolerance.
  • startPoint
  • tolerance
  • shapeUnit
    • Description:This parameter specifies the GeographicUnit for the Multineline.
  • unitOfTolerance
    • Description:This parameter specifies the distance unit used when considering the tolerance.
GetPointOnALine(StartingPoint,Single)
  • This method returns a PointShape on the line, based on a percentage of the length of the line from either its first or last vertex (as defined by the startingPoint parameter).
  • If you pass 100 or 0 as the percentage of the line, it will return either the first or last vertex, depending on the value of the startingPoint argument.
  • Description:This method returns a PointShape on the line, based on a percentage of the length of the line from either its first or last vertex (as defined by the startingPoint parameter).
  • startingPoint
    • Description:The startingPoint defines whether the method starts at the beginning or the end of the line.
  • percentageOfLine
    • Type:Single
    • Description:This parameter defines the percentage into the line. Valid values are between 0 and 100.
GetPointOnALine(StartingPoint,Double,GeographyUnit,DistanceUnit)
  • This method returns a PointShape on the line, based on a distance on the line from the first or last vertex (as defined by the startingPoint parameter).
  • Passing in a distance of 0 will return either the first or last point on the line, depending on the value of the startingPoint parameter.
  • Description:This method returns a PointShape on the line, based on a distance on the line from the first or last vertex (as defined by the startingPoint parameter).
  • startingPoint
  • distance
    • Description:This parameter specifies the distance into the line you wish to move, in the unit of the shape itself. Valid values must be greater than or equal to 0.
  • shapeUnit
  • distanceUnit
    • Description:This is the DistanceUnit you would like to use for the distance parameter. For example, if you select miles as your distanceUnit, then the distance will be measured in miles.
GetLineOnALine(StartingPoint,Single,Single)
  • This method returns a BaseLineShape, based on a starting position and other factors.
  • None
  • Description:This method returns a BaseLineShape, based on a starting position and other factors.
  • startingPoint
  • startingPercentageOfTheLine
    • Type:Single
    • Description:This parameter defines the starting percentage into the line. Valid values must be greater than 0 and less than or equal to 100.
  • percentageOfTheLine
    • Type:Single
    • Description:This parameter defines the percentage into the line. Valid values must be greater than 0 and less than or equal to 100.
GetLineOnALine(StartingPoint,Single)
  • None
  • startingPoint
  • percentageOfLine
    • Type:Single
GetLineOnALine(StartingPoint,Double,Double,GeographyUnit,DistanceUnit)
  • None
  • startingPoint
  • startingDistance
    • Description:The starting distance from where you will start getting the line. For example, if the line is 3 units long and you have a starting distance of 1 unit, the result will be the last two units of the line. Valid values must be greater than 0. The starting distance will be in the GeographyUnit of the shape.
  • distance
    • Description:The amount of the line you want to get after the startingDistance. Valid values must be greater than 0.
  • shapeUnit
  • distanceUnit
GetLineOnALine(StartingPoint,PointShape)
  • None
  • startingPoint
  • endPointShape
    • Description:The BaseLineShape returned will be between the startingPoint and the endPointShape specified in this parameter.
GetLineOnALine(PointShape,PointShape)
  • None
  • Description:This method returns a BaseLineShape based on a start PointShape and an end PointShape.
  • startPointShape
    • Description:The startPointShape defines where you will start to get the line. If it does not stand on this MultilineShape, the closest point on the MultilineShape will be the start PointShape.
  • endPointShape
    • Description:The endPointShape defines where you will stop getting the line. If it does not stand on this MultilineShape, the closest point on the MultilineShape will be the end PointShape.
RemoveVertex(Vertex)
  • This method removes the selected vertex from multiline shape.
  • Description:If remove sucess it will return true, otherwise return false.
  • selectedVertex
    • Type:Vertex
    • Description:The selected vertex must be a vertex of multiline shape, otherwise it will return false and multiline shape will keep the same.
ToMultiPolygonShape()
GetAccurateLength(Int32,DistanceUnit,DistanceCalculationMode)
  • shapeSrid
GetAccurateLength(String,DistanceUnit,DistanceCalculationMode)
  • shapeProj4ProjectionParameters
GetLength(GeographyUnit,DistanceUnit)
ScaleUp(Double)
  • percentage
ScaleDown(Double)
  • percentage
ConvexHull()
  • tolerance
  • tolerance
Union(LineBaseShape)
Union(Feature)
  • targetFeature
GetIntersection(Feature)
  • targetFeature
LoadFromWellKnownData(String)
  • wellKnownText
GetWellKnownText()
GetGeoJson()
GetWellKnownText(RingOrder)
  • outerRingOrder
LoadFromWellKnownData(Byte[])
  • wellKnownBinary
    • Type:Byte[]
GetWellKnownBinary()
  • Type:Byte[]
  • Type:Byte[]
GetWellKnownBinary(RingOrder)
  • Type:Byte[]
  • outerRingOrder
GetWellKnownBinary(RingOrder,WkbByteOrder)
  • Type:Byte[]
  • outerRingOrder
GetBoundingBox()
GetWellKnownType()
CloneDeep()
  • xOffsetDistance
  • yOffsetDistance
  • xOffsetDistance
  • yOffsetDistance
  • distance
  • angleInDegrees
  • distance
  • angleInDegrees
Rotate(PointShape,Single)
  • degreeAngle
    • Type:Single
  • targetFeature
  • targetFeature
GetCenterPoint()
  • distance
  • distance
  • quadrantSegments
  • distance
  • quadrantSegments
  • targetFeature
  • fromPoint
  • toPoint
Validate(ShapeValidationMode)
IsDisjointed(BaseShape)
IsDisjointed(Feature)
  • targetFeature
Intersects(BaseShape)
Intersects(Feature)
  • targetFeature
Touches(BaseShape)
Touches(Feature)
  • targetFeature
Crosses(BaseShape)
Crosses(Feature)
  • targetFeature
IsWithin(BaseShape)
IsWithin(Feature)
  • targetFeature
Contains(BaseShape)
Contains(Feature)
  • targetFeature
Overlaps(BaseShape)
Overlaps(Feature)
  • targetFeature
IsTopologicallyEqual(Feature)
  • targetFeature
GetFeature()
  • columnValues
GetCrossing(BaseShape)
ScaleTo(Double)
  • scale
RemoveVertex(Vertex,MultilineShape)
  • selectedVertex
    • Type:Vertex
  • multilineShape
    • Description:The multiline shape will be removed one vertex.
GetBoundingBoxCore()
  • This method calculates the smallest RectangleShape that encompasses the entire geometry.
  • The GetBoundingBox method calculates the smallest RectangleShape that can encompass the entire geometry by examining each point in the geometry. Depending on the number of PointShapes and complexity of the geometry, this operation can take longer for larger objects. If the shape is a PointShape, then the bounding box's upper left and lower right points will be equal. This will create a RectangleShape with no area. Overriding: Please ensure that you validate the parameters being passed in and raise the exceptions defined above.
CloneDeepCore()
  • This method returns a complete copy of the shape without any references in common.
  • When you override this method, you need to ensure that there are no references in common between the original and the copy.
  • Type:BaseShape
GetCenterPointCore()
ReorderCore(PointShape,Double,GeographyUnit,DistanceUnit)
  • startPoint
  • tolerance
  • shapeUnit
  • unitOfTolerance
GetLengthCore(GeographyUnit,DistanceUnit)
  • This method returns the length of the LineShape.
  • This method is useful when you want to know the total length of a line-based shape. If the shape is a MultilineShape, then the length is the sum of all of its lines. There is also an overload which allows you to specify the returning length in the unit of your choice.
  • Description:The returned length is in the GeographyUnit of the shape.
  • shapeUnit
  • returningUnit
    • Description:This is the DistanceUnit you would like to use for the distance parameter. For example, if you select miles as your returningUnit, then the distance will be returned in miles.
GetPointOnALineCore(StartingPoint,Double,GeographyUnit,DistanceUnit)
  • startingPoint
  • distance
  • shapeUnit
  • distanceUnit
GetLineOnALineCore(StartingPoint,Double,Double,GeographyUnit,DistanceUnit)
  • None
  • startingPoint
  • startingDistance
  • distance
  • shapeUnit
  • distanceUnit
ScaleUpCore(Double)
  • This method increases the size of the LineShape by the percentage given in the percentage parameter.
  • This method is useful when you would like to increase the size of the shape. Note that a larger percentage will scale the shape up faster, as you are applying the operation multiple times. There is also a ScaleDown method that will shrink the shape.
  • percentage
ScaleDownCore(Double)
  • This method decreases the size of the LineShape by the percentage given in the percentage parameter.
  • This method is useful when you would like to decrease the size of the shape. Note that a larger percentage will scale the shape down faster, as you are applying the operation multiple times. There is also a ScaleUp method that will enlarge the shape.
  • percentage
  • This method returns a BaseShape which has been registered from its original coordinate system to another based on two anchor PointShapes.
  • Registering allows you to take a geometric shape generated in a planar system and attach it to the ground in a Geographic Unit.A common scenario is integrating geometric shapes from external programs (such as CAD software or a modeling system) and placing them onto a map. You may have the schematics of a building in a CAD system and the relationship between all the points of the building are in feet. You want to then take the CAD image and attach it to where it really exists on a map. You would use the register method to do this.Registering is also useful for scientific modeling, where software models things such as a plume of hazardous materials or the fallout from a volcano. The modeling software typically generates these models in a fictitious planar system. You would then use the register to take the abstract model and attach it to a map with real coordinates.
  • Type:BaseShape
  • fromPoint
  • toPoint
  • fromUnit
  • toUnit
  • None
  • xOffsetDistance
    • Description:This is the number of horizontal units of movement in the DistanceUnit specified in the distanceUnit parameter.
  • yOffsetDistance
    • Description:This is the number of vertical units of movement in the DistanceUnit specified in the distanceUnit parameter.
  • shapeUnit
  • distanceUnit
  • This method moves the base shape from one location to another based on a distance and a direction in degrees.
  • This method moves the base shape from one location to another, based on an angleInDegrees and distance parameter. With this overload, it is important to note that the distance units are the same GeographicUnit as the shape. For example, if your shape is in decimal degrees and you call this method with a distance of 1, you're going to move this shape 1 decimal degree in direction of the angleInDegrees. In many cases it is more useful to specify the DistanceUnit of movement, such as in miles or yards, so for these scenarios there is another overload you may want to use instead.If you pass a distance of 0, then the operation is ignored.
  • distance
  • angleInDegrees
  • shapeUnit
  • distanceUnit
RotateCore(PointShape,Single)
  • This method rotates the shape a number of degrees based on a pivot point.
  • This method rotates the shape by a number of degrees based on a pivot point. By placing the pivot point in the center of the shape, you can achieve in-place rotation. By moving the pivot point outside of the center of the shape, you can translate the shape in a circular motion. Moving the pivot point further outside of the center will make the circular area larger.
  • pivotPoint
  • degreeAngle
    • Type:Single
  • This method returns the point of the current shape that is closest to the target shape.
  • This method returns the point of the current shape that is closest to the target shape. It is often the case that the point returned is not a point of the object itself. An example would be a line with two points that are far apart from each other. If you set the targetShape to be a point midway between the points but a short distance away from the line, the method would return a point that is on the line but not either of the two points that make up the line.
  • targetShape
    • Type:BaseShape
  • shapeUnit
  • This method computes the distance between the current shape and the targetShape.
  • None
  • Description:This method returns the distance between the current shape and the targetShape.
  • targetShape
    • Type:BaseShape
  • shapeUnit
  • distanceUnit
  • This method returns the well-known text representation of this shape.
  • This method returns a string that represents the shape in well-known text. Well-known text allows you to describe a geometry as a string of text. Well-known text is useful when you want to save a geometry in a format such as a text file, or when you simply want to cut and paste the text between other applications. An alternative to well-known text is well-known binary, which is a binary representation of a geometry object. We have methods that work with well-known binary as well. Below are some samples of what well-known text might look like for various kinds of geometric shapes.POINT(5 17)LINESTRING(4 5,10 50,25 80)POLYGON1)MULTIPOINT(3.7 9.7,4.9 11.6)MULTILINESTRING2)MULTIPOLYGON3),4))
  • outerRingOrder
GetWellKnownTypeCore()
  • This method returns the well-known type for the shape.
  • None
  • This method hydrates the current shape with its data from well-known text.
  • None
  • Description:None
  • wellKnownText
  • This method hydrates the current shape with its data from well-known binary.
  • This is used when you want to hydrate a shape based on well-known binary. You can create the shape and then load the well-known binary using this method.
  • Description:None
  • wellKnownBinary
    • Type:Byte[]
  • This method returns a ShapeValidationResult based on a series of tests.
  • We use this method, with the simple enumeration, internally before doing any kind of other methods on the shape. In this way, we are able to verify the integrity of the shape itself. If you wish to test things such as whether a polygon self-intersects, we invite you to call this method with the advanced ShapeValidationMode. One thing to consider is that for complex polygon shapes this operation could take some time, which is why we only run the basic, faster test. If you are dealing with polygon shapes that are suspect, we suggest you run the advanced test.
  • validationMode
GetCrossingCore(BaseShape)
  • This method returns the crossing points between the current shape and the passed-in target shape.
  • As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • targetShape
    • Type:BaseShape
Scale(Double)
  • factor
GetAccurateLengthCore(String,DistanceUnit,DistanceCalculationMode)
ConvexHullCore()
  • tolerance
UnionCore(IEnumerable<LineBaseShape>)
GetGeoJsonCore()
  • Type:Byte[]
  • outerRingOrder
  • distance
  • quadrantSegments
IsDisjointedCore(BaseShape)
IntersectsCore(BaseShape)
TouchesCore(BaseShape)
CrossesCore(BaseShape)
IsWithinCore(BaseShape)
ContainsCore(BaseShape)
OverlapsCore(BaseShape)
ScaleToCore(Double)
  • scale
Lines
This property is the collection of lines that make up the MultilineShape.
CanRotate
Id
Tag
4) 4 4,7 3,7 5,4 4
thinkgeo.mapsuite.core.multilineshape.txt · Last modified: 2017/03/16 21:59 (external edit)
