GetPointOnALine(StartingPoint,Single)
GetPointOnALine(StartingPoint,Double,GeographyUnit,DistanceUnit)
GetLineOnALine(StartingPoint,Single,Single)
GetLineOnALine(StartingPoint,Single)
GetLineOnALine(StartingPoint,Double,Double,GeographyUnit,DistanceUnit)
GetLineOnALine(StartingPoint,PointShape)
GetLineOnALine(PointShape,PointShape)
GetAccurateLength(String,DistanceUnit,DistanceCalculationMode)
GetLength(GeographyUnit,DistanceUnit)
GetPointOnALineCore(StartingPoint,Double,GeographyUnit,DistanceUnit)
GetLineOnALineCore(StartingPoint,Double,Double,GeographyUnit,DistanceUnit)
GetAccurateLengthCore(String,DistanceUnit,DistanceCalculationMode)
UnionCore(IEnumerable<LineBaseShape>)
