thinkgeo.mapsuite.core.labelinformation
ThinkGeo.MapSuite.Core.LabelInformation
This class represents the location of a piece of a label that may be drawn.
    • ThinkGeo.MapSuite.Core.LabelInformation
LabelInformation()
  • This is the constructor for the class.
  • If you use this constructor, you should set the various properties manually.
LabelInformation(PointShape,String,Double)
  • None
  • positionInScreenCoordinates
    • Description:This parameter is the position of the label that may draw.
  • text
    • Description:This parameter is the text for the label.
  • rotationAngle
    • Description:This parameter is the angle of rotation for the label.
PositionInScreenCoordinates
This property gets and sets the position of a piece of a label, in screen coordinates.
Text
This property gets and sets the text of the label.
This may be the entire label text or a single character.
RotationAngle
This property gets and sets the angle of rotation for the label.
This could be the rotation of the entire label text, a single character, or a set of characters.
thinkgeo.mapsuite.core.labelinformation.txt · Last modified: 2017/03/16 21:59 (external edit)
