thinkgeo.mapsuite.core.rowcolumnrange
ThinkGeo.MapSuite.Core.RowColumnRange
    • System.ValueType
      • ThinkGeo.MapSuite.Core.RowColumnRange
RowColumnRange(Int64,Int64,Int64,Int64)
  • Contructor of the structure to instance a RowColumnRange.
  • minRowIndex
    • Type:Int64
    • Description:Min Row Index which stands for the up boundary.
  • maxRowIndex
    • Type:Int64
    • Description:Max Row Index which stands for the lower boundary.
  • minColumnIndex
    • Type:Int64
    • Description:Min Column Index which stands for the left boundary.
  • maxColumnIndex
    • Type:Int64
    • Description:Max Column Index which stands for the right boundary.
  • This method is an override of the GetHashCode functionality.
  • None
  • This method is an override of the Equals functionality.
  • None
MinRowIndex
Gets or sets the Min Row Index which stands for the up boundary.
  • Type:Int64
MaxRowIndex
Gets or sets the Max Row Index which stands for the lower boundary.
  • Type:Int64
MinColumnIndex
Gets or sets the Min Column Index which stands for the left boundary.
  • Type:Int64
MaxColumnIndex
Gets or sets the Max Column Index which stands for the right boundary.
  • Type:Int64
thinkgeo.mapsuite.core.rowcolumnrange.txt · Last modified: 2017/03/16 21:59 (external edit)
