This is the constructor the for the class. If you use this constructor then you need to set the required properties manually.
This is typically the constructor you want to use for this class. It allows you to pass in the TIFF file you wish to work with. Note that the TIFF file is not accessed or opened until you call the open command of the class.
GeoTiffRasterSource(String,String)
This is typically the constructor you want to use for this class. It allows you to pass in the TIFF file you wish to work with and world file belongs to it. Note that the TIFF file is not accessed or opened until you call the open command of the class.
GeoTiffRasterSource(String,RectangleShape)
This is typically the constructor you want to use for this class. It allows you to pass in the TIFF file you wish to work with and image extent belongs to it. Note that the TIFF file is not accessed or opened until you call the open command of the class.
None.
Event Arguments:ClosedRasterSourceEventArgs
