thinkgeo.mapsuite.core.regexitem
ThinkGeo.MapSuite.Core.RegexItem
This class represents a single Regex Match statement and styles to draw.
    • ThinkGeo.MapSuite.Core.RegexItem
RegexItem()
  • If you use this constructor, you should set the necessary properties manually.
RegexItem(String,AreaStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultAreaStyle.
  • regularExpression
    • Description:This parameter is the regular expression statement you would like to match.
  • areaStyle
    • Type:AreaStyle
    • Description:This parameter is the style you want to draw with if the regular expression matches.
RegexItem(String,LineStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultLineStyle.
  • regularExpression
  • lineStyle
    • Type:LineStyle
RegexItem(String,PointStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultPointStyle.
  • regularExpression
  • pointStyle
RegexItem(String,TextStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultTextStyle.
  • regularExpression
  • textStyle
    • Type:TextStyle
RegexItem(String,Collection<Style>)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the CustomStyles.
  • regularExpression
  • styles
    • Type:Collection<Style>
    • Description:This parameter represents the styles you want to draw with if the regular expression matches.
RegularExpression
This property gets and sets the regular expression text used for matching.
This should be a valid regular expression string. Formatting regular expression strings is outside the scope of this documentation; however, there are many useful resources on the web for learning about regular expressions.
CustomStyles
This property gets the collection of custom styles.
The custom styles allow you to use styles other than the default style properties of the class. In this way, you can use a DotDensityStyle or any other style in the API.
DefaultAreaStyle
This property gets and sets the default AreaStyle. You should use this style if your features are area-based.
The default style allows you to directly set properties on the styles without having to create a new style each time. You can start simply by setting properties like color, etc. This makes modifying styles very easy.
DefaultLineStyle
This property gets and sets the default LineStyle. You should use this style if your features are line-based.
DefaultPointStyle
This property gets and sets the default PointStyle. You should use this style if your features are point-based.
DefaultTextStyle
This property gets and sets the default TextStyle. You should use this style if your features are text-based (such as labels).
thinkgeo.mapsuite.core.regexitem.txt · Last modified: 2017/03/16 21:59 (external edit)
