thinkgeo.mapsuite.core.buildingindexshapefilefeaturesourceeventargs
ThinkGeo.MapSuite.Core.BuildingIndexShapeFileFeatureSourceEventArgs
This class represents the parameters passed in through the BuildingIndex event in ShapeFileFeatureSource class.
      • ThinkGeo.MapSuite.Core.BuildingIndexShapeFileFeatureSourceEventArgs
BuildingIndexShapeFileFeatureSourceEventArgs()
  • This is the default constructor of the event args.
  • If you use this constructor, you have to set the properties manually.
BuildingIndexShapeFileFeatureSourceEventArgs(Int32,Int32,Feature,DateTime,Boolean)
  • This is the constructor of the event args by passing the desired parameters.
  • recordCount
  • currentRecordIndex
  • currentFeature
  • startProcessTime
    • Type:DateTime
  • cancel
BuildingIndexShapeFileFeatureSourceEventArgs(Int32,Int32,Feature,DateTime,Boolean,String)
  • recordCount
  • currentFeature
  • startProcessTime
    • Type:DateTime
  • cancel
  • shapePathFileName
BuildingIndexShapeFileFeatureSourceEventArgs(Int32,Int32,Feature,DateTime,String)
  • recordCount
  • currentFeature
  • startProcessTime
    • Type:DateTime
  • shapePathFileName
RecordCount
Gets the total record count to build rTree index.
CurrentRecordIndex
Gets the current record index for building rTree index.
CurrentFeature
Gets the current feature for building rTree index.
StartProcessTime
Gets the starting process time for building the index.
  • Type:DateTime
Cancel
Gets or sets to see if we need to cancel the building index of current record.
ShapePathFileName
thinkgeo.mapsuite.core.buildingindexshapefilefeaturesourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
