thinkgeo.mapsuite.core.spatialindex
ThinkGeo.MapSuite.Core.SpatialIndex
SpatialIndex()
Add(BaseShape)
Add(Feature)
  • feature
Delete(Feature)
  • feature
Delete(BaseShape)
Close()
GetFeatureCount()
GetFeatureIdsIntersectingBoundingBox(RectangleShape)
  • Type:Collection<String>
Open()
AddCore(Feature)
  • feature
DeleteCore(Feature)
  • feature
CloseCore()
GetFeatureCountCore()
GetFeatureIdsIntersectingBoundingBoxCore(RectangleShape)
OpenCore()
IsOpen
CanDelete
IsOpenCore
thinkgeo.mapsuite.core.spatialindex.txt · Last modified: 2017/03/16 21:59 (external edit)
