thinkgeo.mapsuite.core.ongeoserializedattribute
ThinkGeo.MapSuite.Core.OnGeoserializedAttribute
When applied to a method, specifies that the method is called after serialization of an object graph.
    • System.Attribute
      • ThinkGeo.MapSuite.Core.OnGeoserializedAttribute
OnGeoserializedAttribute()
  • Initializes a new instance of the OnGeoserializedAttribute class.
Match(Object)
IsDefaultAttribute()
TypeId
thinkgeo.mapsuite.core.ongeoserializedattribute.txt · Last modified: 2017/03/16 21:59 (external edit)
