UnmanagedProj4Projection(Int32,Int32)
UnmanagedProj4Projection(String,Int32)
UnmanagedProj4Projection(Int32,String)
ConvertToExternalProjection(GeoImage,RectangleShape,RectangleShape)
ConvertToExternalProjection(BaseShape)
ConvertToExternalProjection(IEnumerable<Vertex>)
GetEpsgParametersString(Int32)
GetEsriParametersString(Int32)
GetGoogleMapParametersString()
GetLocalUtmZoneParametersString(Feature,String)
GetLocalUtmZoneParametersString(Feature,Int32)
GetLocalUtmZoneParametersString(BaseShape,String)
GetLocalUtmZoneParametersString(BaseShape,Int32)
GetLocalUtmZoneNumber(Double,Double)
GetLocalUtmZoneNumber(Feature,String)
GetLocalUtmZoneNumber(Feature,Int32)
GetLocalUtmZoneNumber(BaseShape,String)
GetLocalUtmZoneNumber(BaseShape,Int32)
GetGeographyUnitFromPrj(String)
ConvertToExternalProjectionCore(Double[],Double[])
ConvertToInternalProjectionCore(Double[],Double[])
ConvertToExternalProjectionCore(GeoImage,RectangleShape)
ConvertToExternalProjectionCore(GeoImage,RectangleShape,RectangleShape)
The default boundary is(-179.9, 89.9, 179.9, -89.9). That means when I want to project a PointShape(-179,91,89.91) out, in fact what it projects is (-179.9,89.9) because of its out of boundary.
InternalProjectionParametersString
Gets or sets the Proj4 text parameter for the from projection. This parameter typically look like “+Proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs”.
ExternalProjectionParametersString
Gets or sets the Proj4 text parameter for the to projection. This parameter typically look like “+proj=utm +zone=33 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs”.
