<!– Class –>
SridProjection | Int32, Int32 |
CloneDeep | Projection | ||
Close | Projection | ||
ConvertToExternalProjection | RectangleShape | Projection | |
ConvertToExternalProjection | BaseShape | Projection | |
ConvertToExternalProjection | Double, Double | Projection | |
ConvertToExternalProjection | Feature | Projection | |
ConvertToInternalProjection | BaseShape | Projection | |
ConvertToInternalProjection | Feature | Projection | |
ConvertToInternalProjection | Double, Double | Projection | |
ConvertToInternalProjection | RectangleShape | Projection | |
*GetExternalGeographyUnit | Projection | ||
*GetInternalGeographyUnit | Projection | ||
Open | Projection | ||
*GetExternalGeographyUnitCore | Projection | ||
*GetInternalGeographyUnitCore | Projection | ||
CloneDeepCore | Projection | ||
CloseCore | Projection(overriden) | ||
ConvertToExternalProjectionCore | Double[], Double[] | Projection(overriden) | |
ConvertToInternalProjectionCore | Double[], Double[] | Projection(overriden) | |
MemberwiseClone | Object | ||
OpenCore | Projection(overriden) |
FromSrid | Int32 | ||
IsOpen | Boolean | Projection | |
ToSrid | Int32 |
CanReproject | Boolean | Projection |
| fromSrid | Int32<!– System.Int32 –> | |
| toSrid | Int32<!– System.Int32 –> |
| Projection<!– ThinkGeo.MapSuite.Core.Projection –> |
<!– ThinkGeo.MapSuite.Core.Projection –> Go Back
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| rectangleShape | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> |
| baseShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> |
| Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> |
| x | Double<!– System.Double –> | |
| y | Double<!– System.Double –> |
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
| feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
<!– ThinkGeo.MapSuite.Core.Projection(overriden) –> Go Back
| Vertex[]<!– ThinkGeo.MapSuite.Core.Vertexthinkgeo.mapsuite.core.sridprojection –> |
| x | Double[]<!– System.Doublethinkgeo.mapsuite.core.sridprojection –> | |
| y | Double[]<!– System.Doublethinkgeo.mapsuite.core.sridprojection –> |
<!– ThinkGeo.MapSuite.Core.SridProjection –> Go Back
