This class represents the MrSid raster source.
MrSidRasterSource(String,String)
MrSidRasterSource(String,RectangleShape)
GetImageCore(RectangleShape,Int32,Int32)
GetWrappingImageRight(RectangleShape,Double,Double,RectangleShape)
This property gets or sets the file name and path of the MrSid image you are working with.
If you wish to change the file the class is working with you would want to change it here. You cannot change the file you are working with while the class is in an open state.
If set the SuppressClose to ture, then the RasterSource will not be closed even you call the Close API.
This property returns true if the RasterSource has projection text, false if it does not.
This protected virtual method is called from the concrete public property HasProjectionText. Thus, if you inherit RasterSource, please ensure that you override this virtual property to return the correct projection status of your raster source.We will check the HasProjectionText status before you call the GetProjectionText method. It will throw an exception if the HasProjectionText property returns false.
Event Arguments:ClosedRasterSourceEventArgs
