thinkgeo.mapsuite.core.geolineargradientbrush
ThinkGeo.MapSuite.Core.GeoLinearGradientBrush
    • ThinkGeo.MapSuite.Core.GeoBrush
      • ThinkGeo.MapSuite.Core.GeoLinearGradientBrush
GeoLinearGradientBrush(GeoColor,GeoColor,GeoLinearGradientDirection)
  • Create an instance of GeoLinearGradientBrush by passing a gradient start color and gradient end color followed by the gradient direction enum.
  • startColor
    • Type:GeoColor
    • Description:This parameter specifies the starting GeoColor of the GeoLinearGradientBrush.
  • endColor
    • Type:GeoColor
    • Description:This parameter specifies the endding GeoColor of the GeoLinearGradientBrush.
  • direction
    • Description:This parameter specifies the GeoLinearGradientDirection enumeration of the GeoLinearGradientBrush.
GeoLinearGradientBrush(GeoColor,GeoColor,Single)
  • Create an instance of GeoLinearGradientBrush by passing a gradient start color and gradient end color followed by the gradient direction angle.
  • startColor
    • Type:GeoColor
  • endColor
    • Type:GeoColor
  • directionAngle
    • Type:Single
    • Description:This parameter specifies the direction angle value of the GeoLinearGradientBrush.
GeoLinearGradientBrush()
  • Create a new instance of the GeoLinearGradientBrush with default settings.
CloneDeep()
CloneDeepCore()
StartColor
Gets or sets the starting GeoColor of the gradient.
EndColor
Gets or sets the ending GeoColor of the gradient.
DirectionAngle
Gets or sets the Direction angle of the GeoLinearGradientBrush.
  • Type:Single
WrapMode
Gets or sets a GeoWrapMode enumeration that indicates the wrap mode for the GeoLinearGradientBrush.
Id
  • Type:Int64
thinkgeo.mapsuite.core.geolineargradientbrush.txt · Last modified: 2017/03/16 21:59 (external edit)
