thinkgeo.mapsuite.core.geolineargradientdirection
ThinkGeo.MapSuite.Core.GeoLinearGradientDirection
Specifies the direction of a linear gradient.
Items
LeftToRight
  • Summary:Specifies the color should change in a horizontal direction from the left of the display to the right of the display.
RightToLeft
  • Summary:Specifies the color should change in a horizontal direction from the right of the display to the left of the display.
TopToBottom
  • Summary:Specifies the color should change in a horizontal direction from the top of the display to the bottom of the display.
BottomToTop
  • Summary:Specifies the color should change in a horizontal direction from the bottom of the display to the top of the display.
UpperLeftToLowerRight
  • Summary:Specifies the color should change in a horizontal direction from the upper left of the display to the lower right of the display.
LowerRightToUpperLeft
  • Summary:Specifies the color should change in a horizontal direction from the lower right of the display to the upper leftof the display.
LowerLeftToUpperRight
  • Summary:Specifies the color should change in a horizontal direction from the lower left of the display to the upper right of the display.
UpperRightToLowerLeft
  • Summary:Specifies the color should change in a horizontal direction from the upper right of the display to the lower left of the display.
thinkgeo.mapsuite.core.geolineargradientdirection.txt · Last modified: 2017/03/16 21:59 (external edit)
