thinkgeo.mapsuite.core.geowrapmode
ThinkGeo.MapSuite.Core.GeoWrapMode
This will allow you to achieve a number of different effects. We suggest you try them out with your own textures and see which one looks best for your image.
Items
Tile
  • Summary:The texture is tiled to fill the entire area.
Clamp
  • Summary:The texture will not be tiled.
TileFlipX
  • Summary:Reverse the texture horizontally and then tile the texture.
TileFlipY
  • Summary:Reverse the texture vertically and then tile the texture.
TileFlipXY
  • Summary:Reverse the texture horizontally and vertically and then tile the texture.
thinkgeo.mapsuite.core.geowrapmode.txt · Last modified: 2017/03/16 21:59 (external edit)
