thinkgeo.mapsuite.core.geosolidbrush
ThinkGeo.MapSuite.Core.GeoSolidBrush
    • ThinkGeo.MapSuite.Core.GeoBrush
      • ThinkGeo.MapSuite.Core.GeoSolidBrush
GeoSolidBrush()
  • This is the constructor used to create a new GeoSolidBrush.
  • None
GeoSolidBrush(GeoColor)
  • None
  • color
    • Type:GeoColor
    • Description:This parameter represent the color of the GeoSolidBrush.
CloneDeep()
CloneDeepCore()
Color
This property gets or sets the color of the GeoSolidBrush.
Id
  • Type:Int64
thinkgeo.mapsuite.core.geosolidbrush.txt · Last modified: 2017/03/16 21:59 (external edit)
