thinkgeo.mapsuite.core.iconstyle
ThinkGeo.MapSuite.Core.IconStyle
This class displays an icon with text from the data of the feature.
    • ThinkGeo.MapSuite.Core.Style
      • ThinkGeo.MapSuite.Core.PositionStyle
        • ThinkGeo.MapSuite.Core.TextStyle
          • ThinkGeo.MapSuite.Core.IconStyle
IconStyle()
If you use this, then you should set the properties manually – such as the column name, font, solid brush and the image.
IconStyle(String,String,GeoFont,GeoSolidBrush)
This constructor allows you to pass in the path to the icon, along with the column name, font and solid brush to use. This is the most commonly used constructor. If you need to use an image from a stream, then you should use the constructor that takes a GeoImage.
  • iconPathFilename
    • Description:This parameter is the path and filename of the icon you want to use.
  • textColumnName
    • Description:This parameter is the column name from which to get the data for the text.
  • textFont
    • Type:GeoFont
    • Description:This parameter is the font used to draw the text on the icon.
  • textSolidBrush
    • Description:This parameter is the solid brush that is used to draw the text on the icon.
IconStyle(GeoImage,String,GeoFont,GeoSolidBrush)
This constructor allows you to use a GeoImage instead of specifying a path and filename of the icon. This is commonly used if the image comes from a stream.
  • iconImage
    • Type:GeoImage
    • Description:This parameter is the image to use in this style.
  • textColumnName
  • textFont
    • Type:GeoFont
  • textSolidBrush
CloneDeep()
  • Type:Style
  • features
    • Type:IEnumerable<Feature>
  • shapes
    • Type:IEnumerable<BaseShape>
GetRequiredColumnNames()
  • Type:Collection<String>
DrawSample(GeoCanvas)
SaveStyle(String)
  • filePathName
SaveStyle(Stream)
  • stream
    • Type:Stream
  • Description:None
  • features
  • canvas
    • Type:GeoCanvas
  • labelsInThisLayer
  • labelsInAllLayers
GetLabelingCandidateCore(Feature,GeoCanvas)
This method determines which labels will be candidates for drawing.
This overridden method is called from the concrete public method GetLabelingCandidate. In this method, we determine if the feature passed in will be a candidate for drawing. If you have the grid method enabled, then we determine this by ensuring that only one label will be eligible per grid cell. In this way, we can ensure that labels always draw in the same place at the same scale.
  • Type:Collection<LabelingCandidate>
  • Description:This method returns a collection of labeling candidates.
  • feature
    • Type:Feature
  • canvas
    • Type:GeoCanvas
GetRequiredColumnNamesCore()
FilterFeatures(IEnumerable<Feature>,GeoCanvas)
  • Type:Collection<Feature>
  • features
FilterFeaturesCore(IEnumerable<Feature>,GeoCanvas)
  • features
AbbreviateText(Feature,GeoCanvas)
  • feature
AbbreviateTextCore(Feature,GeoCanvas)
  • feature
GetLabelingCandidates(Feature,GeoCanvas)
  • feature
CheckDuplicate(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckDuplicateCore(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckOverlapping(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
CheckOverlappingCore(LabelingCandidate,GeoCanvas,Collection<SimpleCandidate>,Collection<SimpleCandidate>)
lD8=(PolygonShape,String,GeoCanvas)
  • text
Format(String,BaseShape)
  • text
  • labeledShape
FormatCore(String,BaseShape)
  • text
  • labeledShape
OnFormatting(FormattingPositionStyleEventArgs)
OnFormatted(FormattedPositionStyleEventArgs)
CloneDeepCore()
  • Type:Style
IconFilePathName
This property gets and sets the filename and path for the image you want to use in the style.
You can also optionally use the IconImage property if the image you want to use is derived from a stream.
IconImage
This property gets and sets the GeoImage you want to use for the image.
You will typically want to use this property if your image is derived from a stream. Otherwise, you can use the IconFilePathName property to specify where the icon is located and we will handle the rest.
IconImageScale
This property gets and sets the scale of the image you want to draw.
This property allows you to scale the image up and down depending on how large or small you want it. It can be changed dynamically, so you could change it at every scale level to resize the bitmap based on the current scale. A scale of 1 would be the original size, while a scale of 2 would double the size. A scale of .5 would reduce the size of the image by half, and so on.
SuppressPartialLabels
This property gets and sets whether a partial label in the current extent will be drawn or not.
This property provides a solution to the “cut off” label issue in Map Suite Web Edition and Desktop Edition, which occurs when multiple tiles exist. When you set this property to true, any labels outside of the current extent will not be drawn.
XOffsetInPixel
  • Type:Single
YOffsetInPixel
  • Type:Single
FittingLineInScreen
FittingPolygonInScreen
CustomTextStyles
RotationAngle
TextFormat
NumericFormat
DateFormat
TextSolidBrush
Font
HaloPen
TextColumnName
Mask
MaskMargin
Advanced
ForceHorizontalLabelForLine
SplineType
DrawingLevel
LabelPositions
PolygonLabelingLocationMode
MaxNudgingInPixel
NudgingIntervalInPixel
  • Type:Single
BestPlacementSymbolWidth
  • Type:Single
BestPlacementSymbolHeight
  • Type:Single
AbbreviationDictionary
LeaderLineStyle
LeaderLineRule
LeaderLineMinimumLengthInPixels
  • Type:Single
GridSize
DuplicateRule
OverlappingRule
AllowLineCarriage
ForceLineCarriage
FittingPolygon
LabelAllPolygonParts
LabelAllLineParts
FittingPolygonFactor
TextLineSegmentRatio
BestPlacement
PointPlacement
MaskType
IsActive
RequiredColumnNames
Filters
xT8=
AllowSpline
uBs=
FiltersCore
Formatting N/A
Event Arguments:FormattingPositionStyleEventArgs
Formatted N/A
Event Arguments:FormattedPositionStyleEventArgs
thinkgeo.mapsuite.core.iconstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
