thinkgeo.mapsuite.core.splinetype
ThinkGeo.MapSuite.Core.SplineType
This enumeration represents the spline type for labeling.
Items
Default
  • Summary:Default SplineType provided in PositionStyle.
  • Summary:This SplineType will label the text in a line type without any spling effects, this kinds of type will gain better performance compare to StandardSplining.
StandardSplining
  • Summary:This SplineType will label the text in a standard Spline way, it will have much better outlook in some situations while it will lose slightly some performance.
ForceSplining
  • Summary:This SplineType will force the labe text using Spline way, otherwise the label won't display.Usually it is just used for Asian languages like Chinese or Japanese.
thinkgeo.mapsuite.core.splinetype.txt · Last modified: 2017/03/16 21:59 (external edit)
