thinkgeo.mapsuite.mvcedition.yahoooverlay
ThinkGeo.MapSuite.MvcEdition.YahooOverlay
<!– Class –> Represents an overlay object that gets images from the Yahoo Maps server.
The YahooOverlay registers Yahoo Maps' Javascript library to the page and gets the images from the Yahoo Maps server. The YahooOverlay can only be the base overlay of the map, which acts as the background layer over which other overlays are laid.
Public MethodYahooOverlay Initialize an instance of the YahooOverlay class.
Public MethodYahooOverlay String Initialize an instance of the YahooOverlay class with the overlay identifier specified.
Public MethodYahooOverlay YahooMapType Initialize an instance of the YahooOverlay class with the overlay identifier specified.
Public MethodYahooOverlay String, YahooMapType Initialize an instance of the YahooOverlay class with the overlay identifier and the Yahoo map type specified.
Public MethodFromJson String Overlay Load this object from a json string.
Public MethodGetType Object
Public MethodToJson Overlay Returns a JSON string which contains the information for creating an overlay at the client side.
Public MethodToString Object
Protected MethodRegisterJavaScriptLibraryCore Page Overlay(overriden) Registers the Yahoo Maps Javascript library URL string to the client HTML page.
Public PropertyAutoRefreshInterval TimeSpan Overlay Gets or sets the time interval in which the MarkerOverlay refreshes itself.
Public PropertyId String Overlay Gets the identifier for the overlay to be found.
Public PropertyIsBaseOverlay Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyIsVisibleInOverlaySwitcher Boolean Overlay Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
Public PropertyJavaScriptLibraryUri Uri Gets or sets a URI used for loading the Yahoo Maps Javascript library.
Public PropertyName String Overlay Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
Public PropertyOnClientAutoRefreshTick String Overlay(overriden) Don't support auto tick event by default.
Public PropertyOpacity Single Overlay Gets or sets the opacity level of the overlay.
Public PropertyYahooMapType YahooMapType Gets or sets a value that determines which type of Yahoo Map to display.
Protected PropertyOverlayType String Overlay(overriden) Gets a string that indicates the overlay type.
YahooOverlay()
Overloads
Name Type Description
Go Back
YahooOverlay(String)
Overloads
id String<!– System.String –> The identifier string used for finding the overlay.
Go Back
YahooOverlay(YahooMapType)
yahooMapType YahooMapType<!– ThinkGeo.MapSuite.MvcEdition.YahooMapType –> The map type of the overlay.
Go Back
YahooOverlay(String, YahooMapType)
Overloads
Go Back
Return Type Description
Boolean<!– System.Boolean –>
FromJson(String)
Void<!– System.Void –>
jsonString String<!– System.String –> a json string
<!– ThinkGeo.MapSuite.MvcEdition.Overlay –> Go Back
Int32<!– System.Int32 –>
Type<!– System.Type –>
ToJson()
String<!– System.String –> A JSON string which is used to create an overlay at the client side.
page Page<!– System.Web.UI.Page –> The page object which contains the map.
<!– ThinkGeo.MapSuite.MvcEdition.Overlay(overriden) –> Go Back
AutoRefreshInterval
Return Type
TimeSpan<!– System.TimeSpan –>
Id
Return Type
IsBaseOverlay
Return Type
IsVisible
Return Type
Return Type
Return Type
Uri<!– System.Uri –>
<!– ThinkGeo.MapSuite.MvcEdition.YahooOverlay –> Go Back
Return Type
Return Type
Opacity
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Return Type
Single<!– System.Single –>
YahooMapType
Return Type
OverlayType
Return Type
thinkgeo.mapsuite.mvcedition.yahoooverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
