This class is use for world map kit, and you also can get map from ThinkGeo world map kit server.
WorldMapKitLayer(String,String)
WorldMapKitLayer(WorldMapKitLayerType,String,String)
WorldMapKitLayer(WorldMapKitLayerType,WebProxy,String,String)
DrawImage(GeoCanvas,Collection<SimpleCandidate>)
Contains(RectangleShape,RectangleShape)
IsExtentWithinThreshold(RectangleShape,Double,Double,Int32,GeographyUnit)
IsExtentWithinThreshold(RectangleShape,Double,Double,Int32,GeographyUnit,Single)
Gets or sets a value that is unique to your client ID, please keep your key secure.
Gets or sets a WorldMapKitProjection represents which projection will be use.
This property gets or sets the proxy used for requesting a Web Response.
Is the current scale is beyond this value, the map will not render.
Is the current scale is less than this value, the map will not render.
This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
This property indicates whether a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
The value of WorldMapKitLayer is false.
This property returns true if the Layer is open and false if it is not.
Various methods on the Layer require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the Layer Open method. The method will raise an exception if the current Layer is already open.
