map_suite_wpf_desktop_edition_styles_samples
ClusterPoint (WPF)
ClusterPointStyle is integrated into Map Suite's core. In this project you will see how to use the ClusterPointStyle for clustering various features into one. Sometimes, the map may have too many features which are stacked on top of each other making the map illegible at higher zoom levels. Clustering is a useful technique as it allows you to group together various features into one labeled symbol with the count of all the features. This latest sample also includes recent performance enhancements to the clustering API.
Map Suite Wpf Desktop Edition Styles Samples
Filter Style
In today's Wpf project, we show you how to apply the FilterStyle to a layer's display. By using this style, the map will filter the features queried from the source file by checking if a specified column value fits the input condition. This effect can be applied to all the Map Suite products.
Animated Gif
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
Default ValueStyle
Distance Line Style
EditOverlay Styles
Line Style With Increment
Multiple Dot Density Styles
MultiLine Labeling
Projection Distance LineStyle
Side View Icon
Smooth Transparent Route
Weather Line Style
Weather Line Style
Adjusted Scaling Image Style
Cached Value Style
ClusterPointStyle
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Displaying One-Way Streets
Doughnut Point Style
Feature Centric Style
Flashing Point Style
Hybrid TextStyle
Image Style
Isolines
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Scaling TextStyle for Polygon
Sized Point Style
Start End LineStyle
TextStyle for Multi Line
Time Based Point Style
Time Line
ValueStyle with Countries
WordWrapped TextStyle
World Sized Image Style
World Sized Text Style
Label Point with Circle Symbol and Mask Description
map_suite_wpf_desktop_edition_styles_samples.txt · Last modified: 2017/03/17 02:11 by tgwikiupdate
