This Quick Start guide is designed to help you start using your Map Suite GPS Tracking Server's web portal. The web portal is the web-based interface that you (and/or your customers) can use to visually track and manage assets, wherever they are located. This guide will introduce you to the common features that you'll be using most often and will walk you through some simple first-time tasks.
An outline of the topics that are covered by this guide:
The Map Suite GPS Tracking Server Quick Start Guide is available in the following formats:
| Download Formats |
| Microsoft Word (zipped) |
