The FeatureSource is the provider of data to the HeatLayer. There are different FeatureSource classes to match the various ways that feature data is stored. It is important that, when you inherit from the HeatLayer, in the constructor you set the FeatureSource you want to use.
If this property is not set, it will use the default HeatStyle.
The HeatLayer only displays when the currentScale is less than or equal to UpperScale and greater than or equal to LowerScale, otherwise it won't show anything.
