thinkgeo.mapsuite.core.layerdrawneventargs
ThinkGeo.MapSuite.Core.LayerDrawnEventArgs
      • ThinkGeo.MapSuite.Core.LayerDrawnEventArgs
LayerDrawnEventArgs()
LayerDrawnEventArgs(Layer,RectangleShape,Object)
  • None
  • currentLayer
    • Type:Layer
    • Description:This parameter is the layer that has drawn.
  • worldExtent
    • Description:This parameter is the world extent that has drawn.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
CurrentLayer
This property gets and sets layer that has drawn.
WorldExtent
This property gets and sets the world extent to draw.
NativeImage
This property gets and sets the GeoImage or native image that we are drawing on.
thinkgeo.mapsuite.core.layerdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
