thinkgeo.mapsuite.core.nativeimagetilecache
ThinkGeo.MapSuite.Core.NativeImageTileCache
This is the base class for NativeTileCache system which inherits from TileCache class.
NativeImageTileCache(String,TileImageFormat,TileMatrix)
  • This is the constructor of the class.
  • cacheId
    • Description:This is the cache identifier which marks its difference with other TileCache.
  • imageFormat
    • Description:This is the imageFormate showing what kind of image we are trying to save.
  • tileMatrix
    • Description:This is the tile matrix system which is used for caculating tiles.
GetTile(RectangleShape)
  • This method returns the NativeImageTile corresponding to the tile bounding box passed in.
  • Description:Returns the NativeImageTile corresponding to the passed in boundingBox.
  • tileBoundingBox
    • Description:The target boundingBox for the tile to fetch.
GetTile(Int64,Int64)
  • This method returns the NativeImageTile corresponding to passed in row and column.
  • Description:Returns the NativeImageTile corresponding to the passed in row and column.
  • row
    • Type:Int64
    • Description:The target row for the tile to fetch.
  • column
    • Type:Int64
    • Description:The target column for the tile to fetch.
GetTiles(RectangleShape)
  • This method returns all the NativeImageTiles within the passed in world extent.
  • Type:Collection<NativeImageTile>
  • Description:Returns a collection of NativeImageTiles within the passed in worldExtent.
  • extent
    • Description:The target worldExtent will be used to fetch all the NativeImageTiles from.
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(Bitmap,RectangleShape,Boolean)
  • bitmap
    • Type:Bitmap
  • saveContainedCellsOnly
SaveTiles(Bitmap,RectangleShape)
  • bitmap
    • Type:Bitmap
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
GetTileCore(Int64,Int64)
  • This abstract method returns the NativeImageTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column.
  • row
    • Type:Int64
  • column
    • Type:Int64
ClearCacheCore()
SaveTileCore(Tile)
  • tile
    • Type:Tile
DeleteTileCore(Tile)
  • tile
    • Type:Tile
TileMatrix
TileAccessMode
NoDataTileImage
  • Type:Bitmap
LoadingTileImage
  • Type:Bitmap
ImageFormat
JpegQuality
  • Type:Int16
CacheId
thinkgeo.mapsuite.core.nativeimagetilecache.txt · Last modified: 2017/03/16 21:59 (external edit)
