Represents an object that encapsulates a Web Map Service (WMS) source.
GetFeatureInfo(ScreenPointF,Int32)
GetFeatureInfo(ScreenPointF,String,Int32)
GetImageCore(RectangleShape,Int32,Int32)
BuildWmsGetFeatureInfoUri(ScreenPointF,String,Int32)
GetFeatureInfoCore(ScreenPointF,String,Int32)
OnOpeningRasterSource(OpeningRasterSourceEventArgs)
GetWrappingImageRight(RectangleShape,Double,Double,RectangleShape)
This property allows the active layers requested from the client to be shown on the map.
When requesting a map, a client may specify the layers to be shown on the map.
This property allows the active styles requested from the client to be shown on the map.
When requesting a map, a client may specify the styles to be shown on the map.
This property gets or sets whether the response map image's background color is transparent or not.
This property gets or sets the desired output format for the map being requested from the WMS.
When requesting a map, a client may specify the output format in which to show the map. Formats are specified as MIME types such as “image/gif” or “image/png”.
This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
This property gets or sets the projected or geographic coordinate reference system to be used.
This property gets or sets the base authentication interface for retrieving credentials for Web Client authentication.
This property indicates the format in which the client wishes to be notified of service exceptions.
Upon receiving a request that is invalid according to the OGC standard, the server shall issue a service exception report. The service report is meant to describe to the client application or its human user the reason(s) that the request is invalid.
This property specifies a dictionary used to update the request sent from the client to the WMS server.
This event is called before sending the reqeust for raster image. It is typical that user want to get the url of reqeust and modify it according to their requirements. For example, user could create a signiture for it, and verify it on the server side.
Event Arguments:SendingWebRequestEventArgs
SentWebRequest
This event is called after sent the request for raster image and the HttpWebResponse has come back.
Event Arguments:ClosedRasterSourceEventArgs
