GetDescriptionString(CogoDirectionType,AngleUnit)
GetTraverseString(CogoDirectionType,AngleUnit)
LoadFromTraverseString(String,CogoDirectionType,AngleUnit)
GetDescriptionStringCore(CogoDirectionType,AngleUnit)
GetTraverseStringCore(CogoDirectionType,AngleUnit)
LoadFromTraverseStringCore(String,CogoDirectionType,AngleUnit)
This porperty denotes if this call is the point of begining. This is the point from which we will begin the polygon
