thinkgeo.mapsuite.core.adornmentlayerdrawneventargs
ThinkGeo.MapSuite.Core.AdornmentLayerDrawnEventArgs
      • ThinkGeo.MapSuite.Core.AdornmentLayerDrawnEventArgs
AdornmentLayerDrawnEventArgs()
  • This is the default constructor for the class.
AdornmentLayerDrawnEventArgs(AdornmentLayer)
  • None
  • adornmentLayer
    • Description:This parameter is the AdornmentLayer that has been drawn.
AdornmentLayer
This property gets and sets the AdornmentLayer that has been drawn.
thinkgeo.mapsuite.core.adornmentlayerdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
