thinkgeo.mapsuite.desktopedition.mappanmode
ThinkGeo.MapSuite.DesktopEdition.MapPanMode
  • This enumeration specifies the behavior type for panning. The default value is StandardPanning.
  • For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.MapPanMode// == Items == Default * Summary:Default value (StandardPanning) of the enumeration. StandardPanning * Summary:This enumeration item means that the map will behave as standard with respect to panning. Disabled * Summary:This enumeration item means that panning will be disabled.
thinkgeo.mapsuite.desktopedition.mappanmode.txt · Last modified: 2017/03/16 21:59 (external edit)
