thinkgeo.mapsuite.core.valueitem
ThinkGeo.MapSuite.Core.ValueItem
This class represents a single value to match and styles to draw.
    • ThinkGeo.MapSuite.Core.ValueItem
ValueItem()
  • If you use this constructor, you should set the necessary properties manually.
ValueItem(String,AreaStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultAreaStyle.
  • value
    • Description:This parameter is the value that will match with the data specified for the feature.
  • areaStyle
    • Type:AreaStyle
    • Description:This parameter is the style you want to draw with if the value matches.
ValueItem(String,LineStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultLineStyle.
  • value
  • lineStyle
    • Type:LineStyle
ValueItem(String,PointStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultPointStyle.
  • value
  • pointStyle
ValueItem(String,TextStyle)
  • It is recommended that you do not use this constructor unless it is absolutely necessary. Instead, you can set the properties directly on the DefaultTextStyle.
  • value
  • textStyle
    • Type:TextStyle
ValueItem(String,Collection<Style>)
  • value
  • customStyles
    • Type:Collection<Style>
    • Description:This parameter represents the styles you want to draw with if the value matches.
Value
This property gets and sets the value that we use to match with the feature data. If the value matches, we use the style for this item.
The value must match exactly. If more complex matching is required, we suggest you use the RegexStyle. The RegexStyle enables you to use regular expressions, which are very powerful for fuzzy matching.
DefaultAreaStyle
This property gets and sets the default AreaStyle. You should use this style if your features are area-based.
The default style allows you to directly set properties on the styles without having to create a new style each time. You can start simply by setting properties like color, etc. This makes modifying styles very easy.
DefaultLineStyle
This property gets and sets the default LineStyle. You should use this style if your features are line-based.
DefaultPointStyle
This property gets and sets the default PointStyle. You should use this style if your features are point-based.
DefaultTextStyle
This property gets and sets the default TextStyle. You should use this style if your features are text-based (such as labels).
CustomStyles
This property gets the collection of custom styles.
The custom styles allow you to use styles other than the default style properties of the class. In this way, you can use a DotDensityStyle or any other style in the API.
thinkgeo.mapsuite.core.valueitem.txt · Last modified: 2017/03/16 21:59 (external edit)
