thinkgeo.mapsuite.core.wmsrasterlayer
ThinkGeo.MapSuite.Core.WmsRasterLayer
Represents an object that encapsulates a Web Map Service (WMS) layer.
      • ThinkGeo.MapSuite.Core.RasterLayer
        • ThinkGeo.MapSuite.Core.WmsRasterLayer
WmsRasterLayer()
  • This is the constructor the for the class. If you use this constructor, then you need to set the required properties manually.
  • None
WmsRasterLayer(Uri)
  • This constructor initializes a new layer, then downloads and parses the service description. In an ASP.NET application, the service description is automatically cached for 24 hours when it is not specified.
  • uri
    • Type:Uri
    • Description:URI of the WMS server.
WmsRasterLayer(Uri,WebProxy)
  • uri
    • Type:Uri
  • proxy
    • Type:WebProxy
    • Description:Proxy to use for the current WMS layer.
GetServerLayerNames()
  • This method returns the names of all layers at the server side.
  • None.
  • Type:Collection<String>
  • Description:This method returns the names of all layers at the server side.
GetServerStyleNames()
  • This method returns the names of all styles at the server side.
  • None.
  • Description:This method returns the names of all styles at the server side.
GetServerOutputFormats()
  • This method returns the output format at the server side.
  • None.
  • Description:This method returns the output format at the server side.
GetServerCrss()
  • This method returns the projected or geographic coordinate reference systems to be used.
GetServerExceptionFormats()
  • This method returns the exception format at the server side.
  • None.
  • Description:This method returns the exception format at the server side.
GetServiceVersion()
  • This API gets the WMS server version of the service.
  • Description:Returning a string reflecting the version of the service in WMS.
GetServerFeatureInfoFormats()
  • This API gets the WMS server FeatureInfo formats of the service.
  • Description:This API returns the FeatureInfo formats supported on the server-side.
GetServerCapabilitiesXml()
  • This API gets the GetCapabilites document of the service.
  • Description:This API returns the GetCapabilites document of the service.
GetRequestUrl(RectangleShape,Int32,Int32)
  • Get the request URL from the client to the WMS.
  • Description:The request URL from the client to the WMS.
  • canvasWidth
    • Description:The returning map width, as well as the drawing canvas width.
  • canvasHeight
    • Description:The returning map height, as well as the drawing canvas height.
GetFeatureInfo(ScreenPointF)
GetFeatureInfo(ScreenPointF,String)
  • infoFormat
GetFeatureInfo(ScreenPointF,Int32)
  • maxFeatures
GetFeatureInfo(ScreenPointF,String,Int32)
  • infoFormat
  • maxFeatures
GetProjectionText()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
GetRequestUrlCore(RectangleShape,Int32,Int32)
  • canvasWidth
  • canvasHeight
GetBoundingBoxCore()
OpenCore()
CloseCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
Uri
This property specifies the URI of the WMS server.
  • Type:Uri
ActiveLayerNames
This property represents the available layers that can be requested from the client and shown on the map.
When requesting a map, a client may specify the layers to be shown on the map.
ActiveStyleNames
This property represents the available styles that can be requested from the client and shown on the map.
When requesting a map, a client may specify the styles to be shown on the map.
OutputFormat
This property gets or sets the desired output format for the map requested from the WMS.
When requesting a map, a client may specify the output format in which to show the map. Format are specified as MIME types such as “image/gif” or “image/png”.
Credentials
This property gets or sets the base authentication interface for retrieving credentials for Web Client authentication.
  • Type:ICredentials
IsTransparent
This property gets or sets whether the response map image's background color is transparent or not.
Proxy
This property gets or sets the proxy used for requesting a Web Response.
  • Type:WebProxy
Crs
This property gets or sets the projected or geographic coordinate reference system to be used.
TimeoutInSecond
This property specifies the timeout of the web request in seconds. The default timeout value is 20 seconds.
Exceptions
This property indicates the format in which the client wishes to be notified of service exceptions.
Upon receiving a request that is invalid according to the OGC standard, the server shall issue a service exception report. The service report is meant to describe to the client application or its human user the reason(s) that the request is invalid.
CapabilitesCacheTimeOut
  • Type:TimeSpan
This property specifies a dictionary used to update the request sent from the client to the WMS server.
HasBoundingBox
This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs.
The override in the WmsRasterLayer sets it to true.
AxisOrder
ImageSource
WrappingMode
WrappingExtent
UpperThreshold
LowerThreshold
HasProjectionText
RequestDrawingInterval
  • Type:TimeSpan
IsOpen
DrawingTime
  • Type:TimeSpan
Attribution
IsVisible
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
KeyColors
IsNegative
IsGrayscale
DrawingExceptionMode
IsOpenCore
SendingWebRequest N/A
Event Arguments:SendingWebRequestEventArgs
SentWebRequest N/A
Event Arguments:SentWebRequestEventArgs
RequestedDrawing N/A
RequestingDrawing N/A
DrawingProgressChanged N/A
DrawingException N/A
DrawnException N/A
DrawingAttribution N/A
DrawnAttribution N/A
thinkgeo.mapsuite.core.wmsrasterlayer.txt · Last modified: 2017/03/16 21:59 (external edit)
