thinkgeo.mapsuite.core.bingmapszoomlevelset
ThinkGeo.MapSuite.Core.BingMapsZoomLevelSet
This class represents the zoom levels used by Bing Maps.
    • ThinkGeo.MapSuite.Core.ZoomLevelSet
      • ThinkGeo.MapSuite.Core.BingMapsZoomLevelSet
BingMapsZoomLevelSet()
  • This class represents the zoom levels used by Bing Maps.
  • If you want to create some layers that match up with Bing Maps layers, you should use this ZoomSet.
GetZoomLevel(RectangleShape,Double,GeographyUnit)
  • screenWidth
GetZoomLevel(RectangleShape,Double,GeographyUnit,Single)
  • screenWidth
  • dpi
    • Type:Single
GetZoomLevelForDrawing(RectangleShape,Double,GeographyUnit,Single)
  • screenWidth
  • dpi
    • Type:Single
GetZoomLevelForDrawing(RectangleShape,Double,GeographyUnit)
  • screenWidth
GetZoomLevels()
GetSnappedZoomLevel(Double)
  • scale
CustomZoomLevels
ZoomLevel01
ZoomLevel02
ZoomLevel03
ZoomLevel04
ZoomLevel05
ZoomLevel06
ZoomLevel07
ZoomLevel08
ZoomLevel09
ZoomLevel10
ZoomLevel11
ZoomLevel12
ZoomLevel13
ZoomLevel14
ZoomLevel15
ZoomLevel16
ZoomLevel17
ZoomLevel18
ZoomLevel19
ZoomLevel20
thinkgeo.mapsuite.core.bingmapszoomlevelset.txt · Last modified: 2017/03/16 21:59 (external edit)
